2nd gen Edge Juice with Attitude
Fuel line size
MBRP Question
jdakin said:
Is It Better That A Drag Box? How Much $
Less HP then a drag box, same overall HP as a regular comp box.
The main difference is the juice has the option of the attitude monitor, or the A2.
Sweet box. A close friend was selected for the beta program a while back. The J/A is loaded with features. EGT, Boost, Trans Temp, Fuel Pressure, Shutdown Timer, alarms, memory, etc. Works like a COMP, 5 levels and 5 sublevels. Having done the install, and driving the truck, I can highly recommend it.
The juice w/att works great, the bottom end seems better that the comp to me. It's also nice have a built in low fuel press warning.
You guys will really like this module, it's to bad it wasn't available earlier.
Holysmokes is working on this group buy I have set the pricing for it and Im sure you will like it. As soon as he gets it all ready it will be started.
I too may be intrested in buying 1 - cheapest I found was =$765. 00 delivered... wich is not bad PM me and You may want to Group buy from them instead. I am in need of one now so hope you guys get this set up soon I like saving Moneys
Holysmokes said:
Im guaging intrest on a group buy. At this time, Im not needing vendors as I already have one. Thanks.
Gentlemen, the quote above says it all. I do not want to see anymore vendors chiming in on this thread. If you are an interested member who wants to be part of the group buy, then post up. If not, then don't post as the sole point of this thread is gauging interest in the group buy.
Holysmokes and Woodsrat, once you decide whether or not to do this deal you need to contact Robin prior to posting any details on this buy. If this is not done, it will be deleted. I am assuming you have both read the guidelines pertaining to group buys.
Sincerely,
Jay Williams
moderator
JayWm
Thank you for your post, That was starting to look like a free for all. I contacted admin a few days ago and it was forwarded to robin.
