Hey Guys & Gals,
Thought I'd chime in here, you know add my $0. 02 from my wonderful experience (or should I say expense) with my 99 4X4 steering.
Here goes:
* 3-Moog Lifetime replacement track bars (in under 50k miles!!!)
* upper & lower ball joints
* Steering dampner shock replacement
* Bilstein shocks (yellow & blue)
* 2" steel front spring spacers
* Wild Country upper & lower tubular control arms w/orange bushings and grease fittings on all ends (8), only use marine type grease - green and real sticky
* Axel Shaft u-Joints (@150k - just to eliminate as a possibility)
* Finally dumped the POS stock design Moog and went w/3rd gen adjustable track bar (SWEET!)
* While inspecting the last Moog trackbar joint I noticed the sector shaft was wobbling side to side as the wheel was being cycled. BINGO, see next item.
* DSS Steering stabilizer
* Basically the Partridge "and" the Pear Tree
Bottom line - "Oh, Baby" Oo. :-laf
I feel the items having the most impact to correct the blasted front end were:
1 - Control Arm Replacement - tubular are way stronger than stock stamped steel, orange bushings are replaceable and able to be greased ,
2 - 3rd gen adj trackbar - no more blasted joint to wear out, can replace bushing (if you ever need to), made it possible to center the housing, versus DCs method of throwing a 3 or 5 mm spacer behind the wheel and stamping "do not remove" on it in an attempt to provide correct geometry, and
3 - The biggest improvement item, DSS Steering Stabilizer - really made the steering, "STEERING" versus the battle to stay on the road. I got lucky @ 152k my sector shaft seal was not leaking at all? if it was I probably would have gone to the reduced lock to lock steering box.
OK there's my $0. 02 (actually more like about $2,000. 00)
