Engine/Transmission (1998.5 - 2002) 3 Melted Pistons
Engine/Transmission (1998.5 - 2002) Trying to get EGTs down
2nd Gen Non-Engine/Transmission brake pads
Had the head taken off for an O-Ring job last weekend and surprise surprise. Three pistons had signs of damage on the top. I have been told that the spray angle was incorrect and therefore not spraying into the bowl. That certainly looks like what happened. The other three pistons and cylinders looked perfect after 110,000 miles. The cylinder walls of the three affected cylinders had the cross hatch marks worn off but no signs of 'real damage'. The good news is the head was flat and I got the O-Ring completed. There was a crack in the head between two exhaust valves but it did not extend into the valve seats.
Now I got a lot of work to do !!!!
Dennis
Gary,
I believe it was 1, 3, and 5. I could be mistaken though.
As I understand it, there was no forewarning whatsoever. The possibility exists for anyone of us to be running around with melted/damaged pistons, and not even know it.
I am glad to hear that the o-ringing went well. Did you re-use the stock head bolts, or go with studs?
Jim
I know it might seem hard to believe but I am not totally sure whose injectors they are. I bought them used. I was told one thing and in trying to confirm it now I am not sure. I don’t want to make a false statement.
Yes, I do have pictures. Aron has pictures too.
Dennis
PS. I am not much of a mechanic. If anybody has any suggestions, they would be appreciated.
Dennis
If the spray pattern was hitting the edge of the bowl(lip) then those injectors would make a good set of cores for say some EDM's, if the melting is in the bowl are were it's suppose to be then your staying in it too long. Running these engine at high EGT's like in a 1/4 doesn't do that, running them high like pulling a long hill will though.
Jim
1, 5, 6 from the photos. Don't have it pulled yet. After talking to people in the know, my suspicion is that the pop off pressures may not have been correct and they were dribbling. They have quite a few miles on them, do injectors wear out ?
dribbling?
if they are dribbling, then wouldn't the damage be located in the piston bowls because the injectors are centered in the combustion chamber?
I bought an engine stand and a engine hoist. Starting to take it out this weekend. I don't think anything else is damaged, so I will rebuild it now. I am hoping its just pistons, rings, crank bearings, and a hone of the cylinders.
This will be a VERY long weekend. I hope I can get it out by Sunday.
Dennis
