Blue Chip Diesel Performance
Date: Thu, 13 May 1999 10:49:22 -0700
From: William Rosenberry -- email address removed --
I just called Blue Chip. they sell a box "about the size of a pack of cigarettes" that will enhance the power on your ISB by adding more fuel.
Dyno numbers they gave me:
@2000 rpm Stock With Box
HP 142 237
TQ 375 612
Now this device only works above 1/2 throttle. There is a little LED that tells you its in "fuel enrichment mode" To install it you need to cut a wire and splice in this box. She said all you need is a pair of pliers and know how to use wire connectors. There will be more information on there web site after this weekend Co$t: $ 795. 00
http://www.bluechipdiesel.com
Date: Thu, 13 May 1999 16:39:50 -0700
As a matter of fact, because I live close by, I drove up to see Chip of Blue Chip last night. I got a first hand look at his electronic marvel, as well as a ride in his new '99 dually. In a word, it's awesome.
With one push of a button, his truck absolutely came alive. It's amazing what he's been able to do with electronics and wires, that used to take all kinds of parts (torque plate, turbo housings, exhaust systems ) to do on the old 12 valve engines.
There were a few other folks there to see it, and every one who drove the truck said things like, "This is a totally different truck! This box makes it fun to drive"!
Hp/torque is around 250/660.
Other nice features are that the box has a little indicator on it - and if you drive mild, it stays off, so it doesn't affect your mileage. And if you don't believe its doing something, just turn it off, mash the pedal, and then turn it on while you're accelerating - it's like getting smacked in the butt.
Installation looks simple too - just hook a few wires on to the wiring harness and it's done. This thing will absolutely make the 12 valve folks jealous, finally. -Jim Smith
