305 x 70 x16 tires
test
12- 14 mpg is something wrong??
anyone try these new Goodyears that are out dont know if they clear in front but they sure look like they fill the wheel well tired of my car tires 245 75 16 michelins I have 26k on truck and they are wore out ( i rotate reguarly) if not 305 anyone use 285
Red Nut
I work in a Goodyear dealer as a tech. and we have install lot of the 305/70/16 with very satisfied customers. The truck has to be a 4x4 ofcourse. Depending on body lean when the wheels are cranked all the wat one way they might slightly rub on the sway bar.
How do these tires work on clearence on a dualie #ad
1996-3500 tst stage 3 plate, K&N air filter,4" exhaust,bigger injectors,b&m trans pan,Amsoil all around,temp gauges out the wazzo,much trans work,double tow 33' 5th wheel and 12' trailer w/motorcycle(Honda Valkyarie Interstate)Also have 1999-2500-stock.
I've been using Dunlop Radial Mud Rover 255/85R16's for the last 21K... about half worn... limited slip rear-end really chewing them up now... I rotate every 5K... 255s added 1. 5" actual ground clearance to truck... filled up wheel-wells a bit but lookin' at commercial medium M/S to replace... in the long run will be cheaper... but OUCH... initial cost kinda high!!!
Rob's 98 Ram2500 SLT RegCab 4X4 12-valve Cummins, Automatic, 4. 10 Axle w/ Lim-Slip, Trailer Tow Pack, 255/85R16 Dunlop Radial Mud Rovers... Silencer Ring disappeared; TC lockup switch, CAT removal, and decent paint next... . 50,000 miles; Wife's 99 Ram1500 SLT QC 4X4 w/360 eng, Automatic, Trailer Tow Pack; STOCKER! 38,000 miles - both daily drivers. If your STROKIN, your CHOKIN... on CUMMINS smoke!!!
[This message has been edited by Yuppie Redneck (edited 09-22-2000). ]
I put 305 on and do they look great WOULD RECOMMEND TO ANYONE
I have a 97 2500HD 4x4 with these tires on it. I mounted them on 8x16 allum rims. I rotate them every 7k miles. I have 27k miles on them and they don't seem to be wearing much. Look good, but what I really like is the improved ride.
