33, 34, or 35 inch tires?
Bout time for tires
I broke a sensor .......
I have a Carli starter suspension sitting in the garage waiting to install on my 06 2500. and i need to replace the factory junk car tires that are on the truck now. I am narrowed down to Toyo a/t's or m/t's. can't decide what size of tread to go with. I want great daily drivability and aggressive looks. won't be off road much, mostly snow and rain covered pavement. will the 35" tire kill my braking ability? will the m/t's anoy the heck out of me? or will i not even hear them over the diesel and exhaust?
thanks
I had 35 MT tires and hard on front steering components. I am going to 285/75/17. They look good and are a little smaller and narrower so should cover all you are looking for with At tread. Toyo and Nitto both make that size.
The Toyo 35 MT look killer and really fit the truck, but if you don't need them they are over kill. I had them on my last truck and only needed them twice in a year and a half. Ride really well for a MT The AT would have been just fine the two times. When it comes time I'll go AT with this truck. I'd like to hear how the BFG 285/75 AT are working for these trucks.
I put 315 BFG's on mine after a 2" leveling kit. They are mounted on the stock steel/chrome rims (I think they are 8" wide). I have not noticed any rub. I put the tires on in early October '09. Have no issues so far and they are not noisy. A buddy of mine has been running 315's on his '96 and '01 regular cabs. The '96 is in the woods every day (he's a logger). He has always had a Dodge in the yard. He has had to buy a lot of tires for heavy pickups. The BFG's just seemed to be the best value and performance. I read a lot of stuff about problems with the BFG's, but I just haven't seen it. My brothers have Chevy's and run them also, just not as big as I can with the Dodge. I guess another thing to consider is your climate. Here in the northwest we don't have egg cooking sun to deal with. It 's easier on the tires.
With the 4. 11's, a bigger tire would give you longer legs. The 315 BFG is a "D" rated tire, so it's a little softer ride than the smaller diameter "E" rated. The "E" tires will generally be better for heavy hauling. If you have a loud exhaust, the change in ratio will move the resonance to a different RPM. It helped quiet the drone when pulling certain hills.
Well, let us start with the load rating, as it's the most important to some. A "D" rated 315/70/17 or 325/70/17(Toyo doesn't list a 315)will have a load rating in the area of 3305lbs, while an "E" rated 265/70/17 will be in area of 3195lbs. Air volume does a world of good for heat dissapation and weight transfer. I have 315/70/17s on an '06 2500, and have had some even wear issues on the front, but a realignment and rotations have helped. I also have them on a 3500, with rear spacers, of course. The ride is superior, as the sidewall flexes and takes a lot of the shock out of the road. I have three sets of 325/70/17 Toyo ATs on three 2500s, and they pull the tire just fine with 3. 73 gears and manual. One is a 6. 7. I don't have a lift, and they will rub at a good twist while turning off road. That doesn't happen very often, so I don't worry about it. The 325s are a little harder on ball joints, while the 315s don't seem to be as bad. Both drive well on my trucks. The Toyo MT is pretty pricey, and for well over $200, they perform very well. I like them, but can't afford or justify putting them on fleet trucks. The A/Ts wear well and perform very well in the sand. The BFGs currently have 35,000 miles on them, and I expect to get another 10-12,000 out of them. The Toyo M/Ts seem to wear very well, too. I have one set that managed 65,000, although they were very thin, and I wouldn't have run them in the mud the last 5,000 or so... . I just wanted to see how long they would go, and we weren't having much wet weather at the time. Mastercraft makes a Courser A/T that wears well, is fairly aggressive, and seems to hold up in the 315/70/17. It is priced a little better, as it's an independent brand. The M/Ts have a wrap around tread with sidewall protection, and are VERY resistant to puncture. The tread design is not nearly as loud as other, similar, tire treads. I don't think it would be too noticeable over wind and diesel noise. The change in engine noise is most likely due to the sidewall of the tire absorbing drivetrain thrust at the ground level. Toyo reccomends the 325/70/17 be mounted on a 9. 5in wide wheel, while 8. 5 is acceptable. I mount them on stock wheels, and have no problems, but can't say as it's right for everyone. Cooper and Mastercraft reccomend 9. 5in wide wheel with their 315s, but 8. 5s are acceptable, as well. Hope this helps clear up some questions. Tire tread is more often dictated by budget than need, and the A/T tread is usually more than adequate for most people. I use them the most, and I run a lot of off road miles. The M/Ts are only for use by me on my personal trucks..... ];[]p
BFG offers an E rated 285-70-17 with a load capacity of 3195@80 psi,almost 600# shy of the Toyo in either the 285-70-17 or 285-75-17 size.
Toyos
I agree with above. I've been running the 285 75 17s on stock rims for 3 years now. Very quiet for a mud tire, wearing well (should get 40,000 miles out of them), and I think this is the perfect size for the 3rd gen. Yes, I had some front end wear like ball joints, steering box and some tie rod ends, but that I attribute that to engineering shortcomings on these axles. Toyos are pricey, but worth it to me.
Love my 285/75/17 Toyo M/Ts on stock wheels... Oo.
does anyone have a picture of the 285/75 17 M/t on a 3rd gen?
the actual size of the 285/75 is 34. 1 X 11. 6
and the 35x12. 5 m/t actual size is 34. 8 X 13. 2 so it's very close. and they are both e rated. i might just go with the 285/75. it's a thinner tire and less than an inch shorter. may be a little easier on dirt kickup and the weak front end.
what BFG's are you guys recommending?
what tire performs the best in snow/ice and rain? the a/t or m/t? because lets face facts. i'm not going to be in mud that much...
You might want to check your tire diameter. NOT to be a smartypants, but the 285/75 is a little shorter than 35. 285(apect)x75(ratio)x2=42,750/2540(constant for P-metric conversion)=16. 8+17(wheel diameter)=33. 83 tire diameter. The 325/70 is 34. 913, and the 315/70 is 34. 36. This is calculated, so no arguments with factory specs, but just the mathmatical formula for calculating tire diameter. Didn't want you to be dissapointed or surprised.....
Your math is fine but the best place to look for tire height is still the spec section from the company who makes the tire. They all list it and tell you what rim width it was done with. A goodyear may or may not be the same od as a michelin in the same size, heck within michelin the as is 31. 4" and the at2 and ms2 are 31. 65" for the same size. They all 3 start with different tread depth when new. at2 is 17/32" ms2 is 13/32" and as is 15/32". Your math gets you in the ballpark when comparing two different sizes.
John
I have to throw a vote in for the Cooper Zeons. I have them in the 305-55-20 which is right at about 33'' in diameter and they look about perfect for my mega. They are E rated at 3195 lbs if memory serves. They have worn beautifully and I expect to get nearly 50 to 55k out of them with proper rotation. They are very quiet and perform very well off road. I used to get stuck with my Nittos at the dunes all the time dragging the TH into camp but I haven't had that happen with the Zeon. Great tires and I will be buying them again. I got them for $275 each from Discount Tire here in Scottsdale.
Try this. Tire Tech Information - Diameter Comparison of Light Truck Tire Sizes
My BFG's are 315/70/17 AT. They are nice and quiet but with a good square shoulder for bite. If you're dealing with Discount, don't pay full price, they will deal with you if you can find a better price somewhere else. I haven't done any winter driving with my big rig yet (we didn't have a winter this year), but I swear by the BFG AT on my Rangers, in snow and heavy rain in W. Washington.
