Details here: TDR Privileges
You can get Toyo Open Country M/T 35/12. 5/17 for about $315 each before shipping. PM me and I'll direct you. I have a set coming tommorrow. Had no problem finding them and I'm on the east coast.
I am running 37s on stock wheels with no lift. My truck has the snow plow package so it sits a little higher. The tires rub on the control arms at full lock but they have never hit sheetmetal. The middle of my tires wear a little bit faster than the outside but it is not enough to affect mileage since I replace tires before they wear down enough to become a liability. Maybe 2/32 difference from center to the edge on my last set.
Just installed Toyo Open Country M/T 35/12. 5/17's today. All I have is the Kore leveling suspension which is about a 2"+ front lift. Tires look awesome.
Truck looks great Bob. That is the color I wanted and could not get. I will probably be putting tires on in the next month or so. I need to order the D25's and get them installed, then decide on a tire. I may try a set of the tires you have, I would like to save a little money. I just don't like overloading them. This year hauling hay I had 6300 lbs on my back axle coming home from redmond. My poor pro comps were really overloaded, and gave me a real uneasy feeling all the way home. I believe you mentioned earlier you had a fifth wheel do you know how heavy it is.
I have a 2006 MC and heard about the weak stock springs... will upgrading to Bilstein shocks and plow package front springs bump the front an inch over stock??? thanks-BJ
I just installed a buckstop on the front and my front despertly needs to be raised. I was thinking about revtek 2 inch spacers, but that will only get me back to stock height. Will it be worth it to upgrade to the plow spring, or will i not see much off a difference?
Also if i do spacers do i need longer shocks?
Could i do leveling spacers and leveling springs to truly get me the level look with the buckstop?
So I finally got it done. Monday night I put in the D25's and Bilstein shocks. Tuesday I got the tires installed. There is just some rubbing on the control arms, other then that they fit good.
