35" Tires will they clear with a leveling kit
Speedo Correction for 315/70r17
AC Fin Sensor Relocation - WHERE???
You can get Toyo Open Country M/T 35/12. 5/17 for about $315 each before shipping. PM me and I'll direct you. I have a set coming tommorrow. Had no problem finding them and I'm on the east coast.
They told me they could get them from another store and it shouldn't be a problem. They quoted me almost that exact price.
Are you going to mount those on stock wheels?
I am running 37s on stock wheels with no lift. My truck has the snow plow package so it sits a little higher. The tires rub on the control arms at full lock but they have never hit sheetmetal. The middle of my tires wear a little bit faster than the outside but it is not enough to affect mileage since I replace tires before they wear down enough to become a liability. Maybe 2/32 difference from center to the edge on my last set.
To figure tire in inches the formula is...
Width= size/25. 4 315/25. 4 = 12. 4
Height=2X width X aspect ratio / 25. 4 + rim size.
2 X 315 X . 70 / 25. 4 + 17 = 34. 36 If for a 17" rim
Just installed Toyo Open Country M/T 35/12. 5/17's today. All I have is the Kore leveling suspension which is about a 2"+ front lift. Tires look awesome.
I'll take some pics tommorrow.
Mike
Mike
Pics would be great, I think I am going to go with the same tires or maybe the Dean M/T SXT with the D25 springs.
Here's a couple of pics of my friend Ken's 2005 Dodge RAM 2500 CTD 4x4 and his 2006 Dodge RAM 2500 CTD 4x4 MegaCab.
OEM wheels and no leveling kit..... tires are LT35x12. 50R17 Mastercraft Courser C/T's.
Greg
Bob V said:
Here is mine
Truck looks great Bob. That is the color I wanted and could not get. I will probably be putting tires on in the next month or so. I need to order the D25's and get them installed, then decide on a tire. I may try a set of the tires you have, I would like to save a little money. I just don't like overloading them. This year hauling hay I had 6300 lbs on my back axle coming home from redmond. My poor pro comps were really overloaded, and gave me a real uneasy feeling all the way home. I believe you mentioned earlier you had a fifth wheel do you know how heavy it is.
Joe
Yo HOOT or anyone that can help... .
I have a 2006 MC and heard about the weak stock springs... will upgrading to Bilstein shocks and plow package front springs bump the front an inch over stock??? thanks-BJ
I just installed a buckstop on the front and my front despertly needs to be raised. I was thinking about revtek 2 inch spacers, but that will only get me back to stock height. Will it be worth it to upgrade to the plow spring, or will i not see much off a difference?
Also if i do spacers do i need longer shocks?
Could i do leveling spacers and leveling springs to truly get me the level look with the buckstop?
Finally Done
So I finally got it done. Monday night I put in the D25's and Bilstein shocks. Tuesday I got the tires installed. There is just some rubbing on the control arms, other then that they fit good.
