GSK Kits.....
I never had to touch the foot petal down to -20 starting preGSK. I notice very little change in very cold idle versus a warm idle back then. The GSK really increase the difference between cold and warm idle. While it is easy enough to hold the pedal down slightly when starting it is a pain to have to keep holding it or add a stick after. I also have a real bad idle bounce (idle rebound) summer and winter. Tempted to put the stock GSKs back in for the winter.
I do not run very high timing (wish it was little higher) run slightly less compression with . 012 thicker gasket difference since head work. What I do have is the very stinky, obnoxious, thick white smoke that starts at temps around 30.
I have my idle set just under 1K. If the GSKs would keep it there when cold it would fire right off. I do run 5w40 Mobil Delvac and premium #2 with Amalgated treatment. Staying below zero all day today with a brisk wind to boot.
jjw
ND
jjw
ND
