Here is what you should expect to see come out when you do the GSK... Take my advice and go in from the side 22mm nut. I couldn't imagine it being much easier - JUST DON'T DROP ANYTHING!
Get a set of dial calipers - Digital ones are available for around $19 or less at Harbor Freight - Northern Tool, etc.
The first thing you remove is the split nut that needs to be removed and replaced at exactly the same depth (. 061 approx) from the top of the bolt that all of these springs slide over.
Once that is off you are home bound - just remove the parts and replace with the new. Put the nut back on to spec as mentioned and rotate the engine at the altenator to do the other side.
Yes - that easy.
Yes - that easy.
