Engine/Transmission (1994 - 1998) 3k GSK problems
2nd Gen Non-Engine/Transmission Speed sensor on drive axle
Engine/Transmission (1994 - 1998) ARP head studs
I installed a 3k GSK on a 1997 and now it idles high. It slowly goes to about 1500 RPM. It idled fine before the install. If I back the clips off 2 clicks, it idles better but wants to almost stall when it first comes down to an idle.
Make sure you have all of the old govenor springs out I still had some stuff left in there and the rpm rose stupid like. Fished in there with a magnet and found some more stuff. Then things were ok.
You should not need to adjust you idle much after a GSK install. If you have to the springs are not setup the way they should be.
