Piers said:Hopefully we'll break 700hp on Diesel only soon. Gotta get a decent CP3, then it shouldn't be a problem at all![]()
Piers said:No secrets. PDR towing twins, HX35/14 with a 58mm wheel, BHT3B/26 underneath, DDP injectors, FASS, TST, PPE, PDR cam. Verified on 2 dyno's, one a Dyno Dynamics load dyno[693hp] the other a Dyno Jet inertia [685hp]
SAlex said:I would love to ride in that truck on the street! Serious necksnapp! Steve
Donn said:What year duramax are you running
Fletcher said:. After exhibiting a panoramic view of Canada (massive traction loss)
Just an FYI, if you go visit PDR, take a Helmet w/you... ... .
Piers said:Hi David, good to hear from you. It's our towing twins, so we keep the boost to 55lbs or less. It hit 54lbs on the load dyno at 1220 pyro, the inertia dyno produced 49lbs boost at 1180 pyro temps. Could only run the TST on level 3X3, anything beyound that produced more heat, smoke & less hp. Seemed as long as we kept the rail above 16 thousand lbs, all was good, soon as you turned the TST up, rail psi dropped and power output went down.
