4" ADT exhaust
Long trip, product reciew
Which bypass to install? AMSOIL or Oilguard?
I purchased the mufflerless 14 gauge 4" dia. system from ADT. It comes with a pre-welded rolled and polished SS tip. Here is the page:
Smokin Diesel
I installed the system by myself without a torch. I had to beat on the front hanger because they mouted it 3/4" too far forward. Including removal of the old system, the whole job took about 3 hours. Just used a die grinder with a cutting wheel, my impact and hand tools. I put band clamps at the lower downpipe joint and at the joint before the axle bend, so I can remove it if needed.
Had a slight drone around 2200 RPM. But I am used to it now. I will probably put some dynamat on the back cab wall and floorboard.
Sounds sweet!
Mark,
Thanks for the response and help. I think it is a great system; I installed it by-myself with-out a welder, and it was cheaper than the other 14 gauge systems that didn't come with a tip. Other than that one problem, everything was a piece of cake.
