Since installing the 215 injectors (see Sig. ) I have had a low rpm stumble. It has been recommended that delivery valves or going to a #4 plate will cure this problem. I'm curious what some of you think makes the most sense. I'm presently waiting for some 181 DV's from Piers, but I'm also a little intrigued about going to the #4 plate. If I do, will that lead to needing more modifications to make it run right? I. E. turbo etc. The stumble is a real pain when stuck in traffic. I would also be concerned about EGT's with the #4. I do have the amsoil filter and the exhaust can breath better now. Thanks
