441/865 W/m
radiator to fan clearance
ULS or Old Age
Ran at Meridian ID on a Dyno Jet -5/19/07 and put down the following numbers. On #2 381/760 and with W/M 441/865 Oo. Oo. I used a mix of 50/50 W/M with my Stage 3 controller was set at 100% and the pump at the stock 150psi setting. I had 1 W/M injector leaking so there should be a little more there. Needless to say I am very happy with those numbers. :D:D
Bob
What I meant was how many holes in the injector tip, and the size of the holes, I do not know what size a DD3 is, for example I have a set of 435s, each injector tip has 5 holes and the hole size is . 014.
Sorry about ther confusion regarding the injectors. All I know is that they are 2nd Gen injectors adapted to the smaller high pressure lines on our 1st gens. They are honed DD3s and they work quite well. Now for the bad news - from what I understand a set now will cost you $1200+ for a set. To the best of my knowledge there were only 2 sets made for 1st Gens. Mine were the 2nd set which cost me $700 for the set. That's when the price went to $1200.
Bob
