Cam someone please post the bad adjustment specs and procedure ?
This thread is closed but, my Build sheet is from Goerend, then I posted the ASTG book in this thread.
https://www.turbodieselregister.com/threads/47re-band-adjustment.271550/#post-2680119
I can never find my threads . At the time I had the dtt transmission the one band adjustment they wanted 1/4 inch clearance and it’s been so long since I’ve had the pan off one I can’t remember what I did . My owners manual says 17 quarts I remember with torque converter with a drain and a double deep mag hi tech pan buying 7 gallons of oil to do the service how much do I need to service the transmission without draining the converter?
I get that, here is one way to find your stuff.I can never find my threads .
You can unchecked the Title box if you think it's not in a Title.
View attachment 139236 View attachment 139237
https://www.turbodieselregister.com...o=relevance&c[title_only]=1&c[user][0]=997239
How bad of an idea is it to change the oil a couple times and get most of the old out. I’ve owned the truck 4 years never serviced the transmission Chrysler recommends every 12,000 milesI get that.
I agree with Ozy ATS+4 is a really great fluid.
That 12k is probably a super expensive schedule to follow. Waste of resources and fluid.
It also looks to be that way going back to the 80's!
For the band, 72" lb, is just snugging up the band takes the slack out.
Then for the front, it's one full turn to 12 o'clock, then keep going and stop at 2 o'clock, just before the second full turn. That's close nuff.
The rear is 2 full turns out to 12 o'clock.
The bands wear, so it's good they are adjustable.
Mine were probably never adjusted, the unit was barely serviced from what I saw they probably just added to it when it leaked out. It had a rough life.
