pattern
Funny, Mine does not appear to work that way.
1. . 2... 3 lock
1... 2... 3... lock OD
the lockup is barely perceptable with about a 100 rpm drop. The OD is unmistakeable with about a 30% drop in rpm. and is the last thing to occur.
It was not what i intially expected, but I have grown to appreciate it.
Now if I can just get it to downshift into 2nd after turning 90 degree corners at light/medium throttle. I have never had any auto trans shift well in that scenario, and I am regularly dropping the shifter into 2nd, just momentarily. (again at light,modest throttle). My Supra twin turbo did the same thing (another learning transmission... )
ah, found this old post. evidently the 2001 shifted as I noted. exactly what mine oes at light to medium throttle...
2000 -2001 Dodge Rams,
The shift pattern on these trucks, is different in that the (PCM)allows a shift from 3rd gear locked up to 4th gear locked up without dis-engaging the tc clutch .
Some of the 1999 Dodge rams have the same shift patterns as the 2000-2001 Dodge rams.
I have personally road tested 2 trucks like this. I have a guy on my web site with a 1999 Dodge ram that also has this shift pattern. I never actually looked at the production date on the 99 Rams with this shift pattern.
SHIFT PATTERN 2000-2001
1-2-3-3rd lock-up- 4th lock-up
Now keep in mind:
The tps can affect the tc clutch application.
The harder the acceleration can determine whether the tc remains locked or un-locked.
The shift patterns described above are with (light to moderate conditions ,70% or less of throttle position)
Bill
Diesel Transmission Technology
