Iron Duke II
The following is how I have always performed the subject check. Drive the truck and get the trans up to operating temp. Park on level ground with the engine running and in neutral, remove the trans dip stick and wipe it off, fully reinsert the trans dip stick and remove it again and check the level indicated, which should be with the hash marks below the s bend. Check it a 2nd and 3rd time if you like just to be certain of your reading.
Today I read a piece published by Power Driven Diesel that cited the following after installing one of their units:
"We start with eight quarts and run it for 10 seconds. We then stop the truck and check the fluid level to make sure there are no false readings. The fluid level should be around the S-bend in the dipstick. After checking and adding fluid, if necessary, check level with the truck running, in neutral. It’s time for a test drive while checking line pressure."
https://powerdrivendiesel.com/how-install-47re-transmission/
Please comment.
Please comment.
