I have a 98 model 2wd with a 47 RE and lately the truck seems to be sticking in second gear. If you get above around 2250 rpms the transmission will not shift from second to third unless you let off the accelerator and then once the rpms drop it will go ahead and shift. Sometimes it works fine though. Or if you are above said rpms you can shift into nuetral and then back to drive and it will go ahead and shift. Has anyone ever experienced this before and if so what is the cure for this problem. Thanks.
