48RE Bogs Engine Down when Cold and 1st Shift from Park
'05 differential fluid capacity
Alternator voltage 14.5
The Problem:
As the subject states my 48RE, built by ATS approximately 87k miles ago, has developed an issue where is pulls the engine RPM way down and nearly stalls the engine. This only occurs when it’s been sitting for a while, ~12 hours or more, and the engine and transmission are cold or ambient temperature. It only occurs on the 1st shift from park, be that reverse or drive. I can make the first shift, it bogs, then put it in park and shift again to R or D and it’s normal, no bog. It’s almost like the torque converter lock-up clutch is partially engaged or dragging, then, when you pull it into gear the torque converter is forced to slip and the suspected dragging clutches drags the engine RPM down to about 500 (from the nominal 750). It almost stalls the engine and creates a small cloud of black smoke as the ECU attempts to keep the engine from stalling. It’s shifted hard from park for a while now but it’s deteriorating.
Other Potential Issues?
On a 15 minute drive up a winding canyon road to my house, gaining about 2000 ft. altitude, my transmission temperature goes from ~170/180F to 225F. During the climb speeds are 20-35 MPH and the torque converter is slipping the entire way. Does this sound like too much heat is being generated?
The Main Question:
What components in the transmission could be causing the bogging engine issue?
2004.5 with ATS transmission built 87k miles ago.
I have a Smarty Touch if that helps with any diagnostics…
Torque Converter is my first guess. Have a respected transmission shop look into the TC, and the shift linkages.
If it were a Ford Gas Engine, I would say look at the coil packs and Spark Plugs. Since a co-worker had very similar issues, and that was his problem. Do these trannies have shifter solenoids like some other trucks? I've seen those go out in other makes of trucks, and they have similar shifting issues.
I had the same problem after I rebuilt transmission, turns out it was my Torque Converter, intermittently would lock and unlock, based on temp, finally one day it just stay locked. The place I bought the Torgue Converter from was nice enough to exchange for a low stall Torque converter.
I drop into neutral once oil pressure has developed. Also manual shift into 2nd gear and you should get lockup @ 25 mph.
