On a 2002 4x4 (3/4) , does the outer axle shaft ( the 2 pieces with the
universal ) just slide out after the hub is removed. ?
Also, will the pumpkin drain ?
If I raise the side working on, ( higher than other side ) will most
of the fluid stay in?
I plan to install the hub conversion, I will change the fluid after completing the
job, just won't to do each side seperate in case there is a problem.
Any other advise appreciated, Note, Have been reading the posts,
like the wheel stud/hub removal procedure... .
