5-Speed Gear Shift Knob
Cold Weather Overdrive Problems
DTT Mod's & TX Seminar is a GO
All right - How do you get the Da-- thing off of the shift extender shaft????
Jim E. - Newbie to Diesels w/2001-2500Quad-4X4-LB-Bronze Beauty
Is it glued on or is it just a press fit? - This is a '01 2500
The insert has a step on its circumference. The lower portion is larger diameter than the part you see. It fits into a groove in the knob. It might be easier to remove if the knob is warm.
If want to replace it with one that reads 1-2-3-4-5-R instead of that stupid L-O business you can buy the different shift emblem from the dealer for under $5.
Illflem: I must have been lucky - mine reads 1 2 3 4 5 R - Somebody must have learned a lesson
If you want to remove the knob, just grab hold of it and twist. To put it back on, you'll need to remove the shift emblem to get to the nut, then reinstall the emblem. Just turn on the radio, make yourself comfortable in the front seat and take your time. Piece of cake.
2001, 3500, Cummins, SLT, 5sp, 3. 54LS, camper/tow package, 4x4, 165 watt backup lights, Thomas powered on-board air system, Grovers.
