6 inch lift block
Fuel pump tests?
Does your fan pull air at idle?
I've been searching the archives for the answer to lifting the rear of my truck. Right now it sits a little too low in the back for me. It is 91 so it has factory 3 inch blocks now and I read that 6 inch blocks were installed in 92 and 93. Can I put these in and not cause any problems. I found a thread about this and a guy said they can role out from in between the axle and leaf springs which is something I'd rather not experience. I figure if they put them in the later ones from the factory I should be alright right?
And if i can get the factory dodge 6 inch blocks, can I just bolt them in and not mess up the angle of the driveshaft? And I will need to get different shocks too.
Thanks Alot
When I bought my 92 it came with the 6" blocks and I had the local dealership replace them under warranty with the 3" blocks. I believe the only thing in addition to the blocks that needed to be changed were the U bolts.
Al
If you go with the 6" blocks. Dodge had a TSB out on driveline vibrations. Part of the cure was to add a 1/2" spacer between the carrier bearing and its mount. With the 6" blocks the driveline angles were to far out. The spacer droped the driveshaft to a better angle and stoped the vibrations.
I did this on my 89. Want to do it to my 91, still need 6"blocks. Reg cab no problem. Had longer u-bolts built, didn't do anything to driveshaft. You might need new shocks-longer ones that is. I never did, but my shocks were stretched out :D.
