Blakers said:Does Rock Auto also have ball joints? Just got back from the dealer (highly recommend on going to Cunningham Dodge in Edinboro, Pa) and the ball joints are not covered by the 7/70. Hard to believe! I might as well do it all myself.
Any part number for ball joints out there?
Thanks.
Nick,
Then how do you put a new one in? Why isn't it just a normal joint arrangement? I like things simple... this doesn't look simple.
Thanks,
Mickey
MickeyMiller said:Nick,
Thanks,
Mickey
BGarofalo said:Speaking of balljoints and u-joints and the such. I went to change the front axle u-joints and became stuck when I went to get the rotor off. Am i doing something wrong here? The rotor just slides over the studs correct? I beat the thing with my trusty B. F. H. to no avail. So I just grabbed the posi lock puller and pulled the hub assembly off with the rotor still attached. How do I get the rotor free without damaging it?
jwilliams3 said:351 is the 6 speed part number.
The auto's get the 295's.
www.rockauto.com has the parts you need and alot cheaper than napa.
http://www.rockauto.com/catalog/catalog.php?carcode=1424652&parttype=2392
ACDELCO Part # 45U0305 for the axle u joints if you cant get the 464.
All the part numbers you need are listed in the beginning of this thread.
steved said:Well, I did a search on my truck at Napa... for a two piece driveshaft they call for a #295 and a #330. The 351s are for a 3 piece driveshaft, unless anyone can say for sure.
I got ujoint problems... both driveshaft and axleshaft... need joints soon!
steved
jwilliams3 said:Front Axle U joints LEFT AND RIGHT (takes 2) #464
Blakers said:Has anyone actually installed a 464 in their front axle? Just checking cause I ordered one from Rock Auto and the inside corners of the joint don't look like they go in quite as far as the original joint. I'm betting it will work, but don't want to be stuck with a truck apart and not have a joint.
Thanks guys!
