I put an 02 6spd in my 96 4x4. It had a 5spd.
I needed to change the crossmember, but you will not have to. The 98 and up has a crossmember that is fatter in the centre and is good for auto. 5spd. and 6spd. My 4x4 shifter was attatched to the NV4500. The 5600 has no mounting for the 4x4 shifter so I had to modify the floorboards to bolt the shifter leaver to the floorboards. I think you have the new centre console with the shifter bolted to the floorboards already, so you won't need to change anything.
-You will need a new flywheel(if you buy the newer 1 3/8" input 6spd. )
-Bellhousing
-Cutch
-1/2" thick spacer that goes between the starter and the adapter plate for the bellhousing.
- lengthen the wire to the speedo. pickup on the back of the transmission
-lengthen the front driveshaft exactly 6"
-shorten the rear driveshaft exactly 6"
-lengthen rod from the T-case lever to the T-case 6"
The transfer case is interchangable between the 5 and 6spds (it is NOT compatible with the auto transfercases)
Everything else will fit fine. It will be a very easy conversion with your 98. If you go to a wrecker you can buy all or trade all the parts + cash. It should take you about 6 hrs to re and re ,not including the time to get your flywheel turned and have your driveshafts done.
If you get the 01 and up 5600 with the 1/38" input shaft you will have a pretty bullet proof trans. shat can handle a lot more more power than the 5spds. It is HUGE at 380# instead of 200#
I traded a wrecker my broken 5 spd. + $2500 for a 2002 with 12,000 miles on it. He included all the parts that I needed. I just had to pay the driveshaft shop $200 to do the driveshafts.
Garry.
