I am a new member and I have a question regarding the gearshift lever on a 6 speed. The lever appears to be rotating as the gear pattern on the knob is turning. I thought it was just the knob but that is tight, so I thought that the shift pattern was an insert in the knob that was moving but that wasn't the case either. It appears that the lever is rotating at a point somewhere in the trans. After about a week of driving the lever rotates around so that the shift pattern indicator is back in the correct position. I don't need to see the shift pattern but is this something anyone else has experienced?
_____________________
2002 Quad Cab 3500, long bed, 4wd, 6spd, HO, 4. 10
