2nd Gen Non-Engine/Transmission 60" Line Of Fire Led
2nd Gen Non-Engine/Transmission soft brake pedal
Engine/Transmission (1998.5 - 2002) Turbo Inlet Hose Clamp
has anyone have these get in the way for the spare tire crank down hole? not sure how wide these are and if it can't make it past that hole.
When I got my line of fire I noticed the same thing. The way it mounts ,you can remove it with a philips head screw driver to gain access to the spare tie crank hole. Do a search as this has been gone over before. Sorry I can't remember the outcome. I ended up with a aftermarket rear bumper and had more room.
Yes it covers the hole for the tire crank. I saw the line of fire on one website where it had a different part number for our application. Basicaly it came with some snaps and other stuff so you could remove it easily. What I did was use several 3" pieces of Dual Lock by 3M (its a bit like velcro but used in more semi permanent applications) Now if I need to get to the crank hole I will just pull off the line of fire and then return when finished. You could probably use peel and stick velcro but Dual Lock is some series good stuff.
Paul
