6CT Model 304 12 Valve
Peter @ Southbend
FASS Spring Question?
I am curious to the application of this motor. It is attached to a 6 speed ZF transmission with a cab over shifter. Console mounted maybe. The shifter is only about 8 inches long.
The part number on the motor is 1241847 if that helps. It has a Holset H1C turbo. It also says Manufactured for DAF By Cummins Mtrs.
Thanks,
Doug
is it in a cabover vw or similar truck i have access to a similar rig for a engien and trans cheap a cab over with a 6speed and 8. 3 in it. . let me knwo what you find out
thanks
deo
