StanHolder
Realized my left turn and brake light inop on trailer only. All other lights on truck and trailer work. It appears the pin for the left brake/turn signal on the truck connecter is only showing 3 volts when the brakes are applied, right pin shows 11.88 volts. When I turn on the signal light the voltage changes but never gets above 10 volts. right side gets up to nearly 12 volts. Disconnect brake controller, no help. Swapped 30A fuses, no help. No obvious wire damage under truck. Thought about removing 7 pin connecter and checking for damage/corrosion. No previous history. Any ideas? Thanks
Stan Holder
2006 2500 Cummins
All Stock
200,000 miles
Stan Holder
2006 2500 Cummins
All Stock
200,000 miles
