Diesel Nut said:I don't know if I am over it, but I have to be darned close! We'll see soon enough.
Orangevale dyno day?
NGM Diesel said:i dont know who's truck that is, but man it sure sounds good.
Tomeygun said:Also:
790/???? (HeberRam) 2005 4x4 auto- B,D,E,I,N,O,T,X,Z
709/???? (John Stewart) 04. 5 CC SB 4wd Auto- A,B,D,E,I,M,TT,X120,Z
From here
lmills said:can't say for sure cause it goes by so fast on the video, but it looks like a truck that has been in my shop before getting worked on :-laf
NGM Diesel said:yea that muffler bearing really helped out in the quarter.
NGM Diesel said:you would be very surprised.![]()
crawler said:SMDiesel built the John Stuart truck summer of 05 and it did 709 in August 05. Those numbers were Diesel and Water meth only.
Now that II did him a pump and Injectors. It has since done just over 850 recently. He has an electronic grimlin right now that has him down. But the quest continues. The truck is a driver and not a queen.
He is Running an II single turbo and a SMD nitrous setup.
His entire setup was re-done: Fuel System, CP3, Injectors, Nitrous, Electronics (all different stuff than before).
He still runs the same cam, stock short block, mild port head.
Also we have a 03 running around with the same setup (except more radical head, and off the shelf electronics) making about 870 consistently.
~Wes~
crawler said:Thank You!
Yours are pretty DXXN awesome too!!
~Wes~
crawler said:NGM Sorry to burst your bubble but things are not as you seem to perceive them.
You are however welcome to call me to discuss the current setup. I have no problem filling you in so that you may make informed comments about John's ride.
Yes you sold John some parts. No they did not all go on the truck. Some were sent back for a little "adjustment" to my specs and some were completely replaced.
As far as the 03 we haven't dynoed it since the change to the new electronics and the new nitrous setup.
But at 870 @ full weight it ran 11. 61 (old setup)
With the new setup it ran 11. 29 sliding around the track quite a bit on the big end. (2wd Quad Short, full weight)
~Wes~
~Wes~
