i decided to work alittle bit on making the 92-2000 stuff work on the 79 body .....
the first thing we worked on was taking the old gas pedal that was made to sit on the floor and you rest your whole foot on it ... ... i decided i wanted a more modern type hanging pedal and the one from the 92 i that i took off was not going to work with the contor of the floor ... ... so
we took the 79 bracket ground it down took it apart ... . then we took an 85ish bracket and pedal took it apart .....
then we made the 85 pedal so it would attach to the 79 bracket .....
then had to modify the 85 pedal so the 92 throttle cable would attach
got all that done and then realized that we did not have full throttle so it all came apart agan and he had to bend it all up to get more pull out of it.
over all i am happy with it, the bottom of the pedal is a little high off the floor but i can probably get a new set of pads for it
as you can also see in the last pic we got the 92 e-brake bolted up and its going to work great
next thing we tired to do was get the holes drilled for the hydro-boost ..... yes i said it hydro-boost ... ...
it started up all well and good, got 2 holes drilled put the boosted up ... ... and quickly realize that we had it positioned 90 dergees off ... . it was sideways
no problem just turn it and drill 2 more holes ... ... got that done and just as soon as they were both drilled and the booster was fitting good, we decided the pop the hood on my 02 to look at how the booster is supposed to work we now had it up side down
2 more holes in the fire wall and we finally had it sitting the right way that took way to long
now we decided to try and put the master cylinder on, no problem right ... . wrong it sticks out too far and is going to hit the intercooler pipeing ... ...
now we have to figure out how to re plumb the intercooler b/c i am determined to make the 2000 or 2001 parts work on the old truck
and finally a shot of all the pedals and shifters
