hi i have an 89 cummins that had tons of power about 6 months ago but its slowly died off just recently its become hard to get it going over 60 on the highway it use to to about 80 with ease i have checked and replaced all the obvious like filters checked timing new lines from the tank they had pin holes in them and the fuel would bleed back down over time making it hard to start i also changed the lift pump its only getting about 12 mpg i ruled out the turbo i rebuilt it and it also doesnt smoke i figured if the turbo was bad i would get some smoke from all the fuel with no boost it seems like its lean because it never smokes except a little bit at startup but no little puff of black when you get on it like it used to oh yeah the injectors are new also and the truck is stock with a little under 300,000 injector pump is about 100,000 old please help before this truck drives me crazy thanks Bill
