90degree fittings for amsoil dual bypass
Mounting NW Custom flaps on a dually
Infinity Stereo - tweeter wiring?
Anyone know the exact size and name fitting for the optional 90degree fitting at the 2 inlet ports on the dual remote system? Thanks
Fittings
The bypass system that will fit our trucks. . the part number is BK11. That is a pair of 90*'s,,1 long and 1 short. .
Rick
RHARVEY, JJRSMP12 was referring to the Amsoil DUAL remote bypass system (BMK-15 for the Cummins powered Rams), not the add-on single remote bypass (BMK-11 as you stated). I purchased the optional 90 degree fittings from my local Amsoil supplier prior to the my installation as I wanted the flexibility to be able to install the kit as I wanted. As it turned out I decided to custom make a pair of Aeroquip Teflon/braided stainless steel hoses using Aeroquip steel fittings for my installation.
JJRSMP12, if I remember correctly, the optional Amsoil 90 degree steel fittings are just add-on fittings. . they do not replace the supplied straight fittings.
update
thanks for the replies. I just decided to go to my local hardware store and purchased a female-to-female straight tube fitting and ran a male-to-male 90 to the femal hose fitting. Should do me fine. I did order and receive CFPP's billet mount adapter and i must say it is super nice. I will install tonight.
The BK11 is the part number for the 90* kit which has 2 fittings. It has 1 long 90* and 1 short 90*. The part number that I stated was gotten off the parts list of the dual remote systems.
Rick
