92' charging problems.... probably a loose wire..
Ok I am not charging, I can charge my battery on a charger and it holds and I can drive it for a day. Technically I have a hydrid diesel/electric lol. I did some searching here. Most of the problems are early 1st gens.
I have the manual on CD, which doesn't work under WinXP unless you do everything manually.
I am correct in stating that a 92 does not have one of those obvious voltage regulators that I used to be so fond of?
I am pretty sure its a loose wire and since there is some non-stock wiring in here, what would be the easiest way to hot wire this thing so at least I can drive. I might be going to Tennessese soon and this thing needs to be rock solid. I am just a little lost on where to begin.
The computer code I think was 4-1 which doesn't really help if its a loose wire.
any ideas??
any ideas??
