Engine/Transmission (1994 - 1998) '93 transplant to '95?
Will an engine from a '93 install without big problems into a '98? What sort of complications might be expected? Thanks. JH
The P7100 can be installed on the 93, providing the 95 is used for donor parts. The gear housing and cover, might need the camshaft and cam gear, you will also need the 95 head, injectors and injector lines.
But if you're not looking to do a major HP increase the '93 injection system will do just fine. Should get a little better MPG because of the dynamic timing.
