This has me pulling out my hair ... ... ... .
I had a leaky valve cover that had the top of the motor covered in oil ..... so I gave it a good bath with brake cleaner and then sprayed everything with a air hose. I put the valve covers back on and tightened everything up ... ..... let it sit for an hour or so making sure everything was dry ... ..... Went to start it and NOTHING ... . I have power in the cab . . clock, radio, lights etc... ... ... When I turn the key to the "Start" position all power goes out ... ..... back to run and all is good. The engine does not even try to turn over. I also noticed that the fuel shutoff solenoid is not pulling up... if I reach down and push it up it will stay ..... I jumped the 2 posts on the bottom of the starter and it spins... but the Fuel Shutoff don't activate so it wont start ... ..... I took the alternator and had it tested to make sure that wasn't the issue and it tested strong...
I have cleaned the connections on the battery, and I even took a battery out of the '03 to make sure that was not the issue... ... .
Please help!
Thank you in advance!
Please help!
