Engine/Transmission (1994 - 1998) 94 throttle rod
Engine/Transmission (1998.5 - 2002) dana 80 rear axle
Engine/Transmission (1998.5 - 2002) Power increase!
There was a recall for the linkage on these, might want to check with the dealer and see if yours was done. If not, you have a free fix. Otherwise I don't have much to offer for adjusting it.
A number of years ago there was advice on adjustments for the rod to get the most out of rod travel that effected the pump, with measurements etc. I did mine at that time but the memory chip has gone on hiatus.
The rod ends are the biggest problem because of the lack of lubrication, and heat environment.
