She ran fine for 230,000 miles, only thing I have replaced is both batteries and a lift pump. I came in from a 2 hr trip last night parked it, got up this morning and it just turns over. Any thoughts????
KingS said:does it try to fire at all well any way have somone try and start it while you watch to see if the fuel shut off solenoid lifts up on the fuel vavle the solenoid is in front of the fuel filter and attached to the fuel pump if it doesn't lift you can tie it up with a coat hanger to start it and undo it to stop the truck or I used a old style choke on off lever for an old car carb. till I got my new on and TST product was the cheapest I found for a new fuel shut solenoid
Jokerswild said:thanks, you were right on spot, the arm doesn't lift, I turn the key on and push it up and it stays up by itself and runs fine, I have one on the way (ebay $135) thanks again... ...
