I'm a newbie here and have been pouring over the wealth of information here,WOW !! Keep up the good work guys. Anyways,here's my problem. I have a 97 2500 4x4 auto,and when you start it up cold,and let it warm up for 10-15 mins,then drive away,it works great for the first couple stops,then it will mysteriously lose drive (revs flare up)and seem like it goes into neutral. None of the forward gears or reverse work. I'll put it into neutral and wait 10-20 secs,and then away it goes. Will work great all day after that. Once it happened sitting at a stop sign,and the truck just revved up (just as if it was put into neutral). It has done this since new,even after several trans services and changing to synthetic ATF. Trans has 190000 KM (including plowing) and has never been opened up. DC dealer has no ideas. I have read above convertor drainback,but i think after 10-15 mins of warm up and 1-2 mins of driving it would refill the convertor. Also,on really cold days (-10 C and below),it does this after I back out of the driveway,or much sooner. Other than this problem,the trans works awesome,and I'm afraid to open it up,because it does work so well. If I don't warm it up as long,the problem doesn't happen as often. Could it be the fluid foaming ?I think I have covered most other stuff (tps adj,band adj,trans temps ok). Any ideas ?
Chris
Chris
