Look, I hate to rain on your parade but no one here is going to say that you will be safe making any kind of modifications without having a way to monitor the results... ... ... ... ... ... ... . With a stock turbo and edge comp on 5 you will cook your turbo very quickly, your little exhaust pipe and your fancy intake are not going to keep it cool... ... ... ... ... ... . you have to know how much boost you have and how hot you are... ... ... ... ... ... By the way it is not a chip it is a box. //??... ... ... . any upgrades need to be done in a balanced way... . an edge comp on 5 with stock injectors is a violent kind of power compared to an edge comp on 2 or 3 and 100 or 80 hp edge injectors... ... ... ... ... . At that point you need to make turbo modifications to keep things cool ... ... ... and its a good idea to put in studs or fire rings at this point and since you got it apart for studs/fire rings you might as well do a cam ... ..... and you cant hardly put it back together with those gay little edge injectors so you spend the money for the 150s ... and now you need more air so maybe you can make a twin set up out of you old turbo and the one you upgraded to... but probably not so the eternal struggle continues... big single or twins?. . Oh yea that stock charge air cooler probably is not going to last long ... ... ... ... ...
Yes all of this with an edge comp. YOU NEED TO BUY THE COMP WITH ATTITUDE AND HAVE A PROFESSIONAL HOOK IT UP ... ... ..... ALSO YOU NEED TO HOOK UP THE GAUGES BEFORE YOU TEST DRIVE IT.
Oh yea, whatever transmission you have now will not last long if you do the above modifications . There is a good possibility that it will not make it out of your driveway if you have a long one.
