Engine/Transmission (1998.5 - 2002) '98 ISB, '01 ISB ETH injector question
Engine/Transmission (1994 - 1998) diffrences in auto and stick
Engine/Transmission (1994 - 1998) Clutch or input shaft????
Yes but you better change the injector tubes on the 98. 5 first. :)
Also, I got that package Saturday, I am taking the "Banks... (etc)" off, and painting it black to match the truck!!! THANKS A LOT MAN!!!!
Andrew
Good deal, glad it got to ya so quickly! Okay, I'm behind the times on the injector tubes, can ya tell me just what ya mean? I'm swapping DDII's with stock if that helps.
Thanks,
Jerry
I think what TDK is getting at here is that
the connector tubes in the 98. 5 are not good to re-use.
I am not familiar with them (before my time), but the 99 and above are reusable.
By the way there called "male connectors" at the factory.
--Justin
The injector tubes you can get from DD I think, they are about $30 i THINK. They will go one the 98. 5. :)
Good Luck,
Andrew
Originally posted by Evan A. Beck
You'll only need the connector tubes IF your engine serial is number 56462592 or earlier... :D
Oh WOW Evan, I forgot ALL about that part of it, thanks for stepping up and reminding my memory. :eek:
Also, like Bob posted, Piers is a GREAT source for them also!! :D
Andrew
I have a set of tubes
Powder Extreme, I have a used set from my ETH which I pulled out trying to solve a rough idle problem, didn't change a thing so I know they are good. Have about 16,000 miles on them. When I bought a new set from Cummins it ran me around $90 for the set ($13 apiece + tax). I have no idea what Piers or DD sells them for. If your serial number is below what Evan quoted drop me a PM. They are nice and clean but I can drop 'em in the ultrasonic cleaner at work and then zip 'em in ziplock bags before sending them.
Evan's quite the source of information, ain't he? I bet he has that serial number memorized :D
Vaughn
Re: I have a set of tubes
Piers sells them for a bit cheaper then you quoted, but the savings might be lost in shipping. I haven't asked DD what they sell them for. I'll check with Cummins here in the next few days, I am going to get a set to have onhand since I have been changing injectors alot.
Vaughn, I already ordered a set from Piers, thanks though. I was at Cummins Wednesday and they didn't have a freakin clue what I was talking about. 2 parts guys and 2 mechanics, no clue whatsoever. So I called PDR right there in the Cummins shop and relayed the reasoning for changing them on the earlier ISB's. They didn't buy it all and were convinced there is no problem and it's just a waste of money. As are injectors bigger than 275's, different turbo's, blah blah blah.
I'm sure glad we have guys like Piers, DD, Edge etc. there for us, if we had to rely on Cummins, we'd all be slow, albeit a whole lot richer ;)
Jerry
Jerry
Not when you think about their Torques Maxes ECM, which is about 10 hp for about $800. :eek: :eek: :eek:
Andrew
Well, that's true, but it still a whole lot cheaper than 5 grand for twin turbos, a grand for a comp box, 600 for injectors, a grand for a clutch and on and on. :D:D:D
