I know I have seen on TDR where there was a repair for the leaking fuel filter drain for a 99?? I see that Geno's has a replacement valve now for $46 and this is where I will go If someone does not have a better solution for a dripping valve?? My 99 has 220k + on it and I drained the canister to change filters after a gel-up incident at -30 f for lows this last 10 days and I have resisted draining the canister (WIF) valve in cold weather because I have read of the leaks caused by doing this, but I did the drain and of course the valve now is dripping fuel very slowly, probably cracked the plastic!! Any suggestions Please/thank you!!
gtwitch in wyoming
gtwitch in wyoming
