2nd of my repair questions.
I need to replace the AC compressor in my truck. (It siezed up, causing burn through of the belt, been running a "bypass" non-AC belt since. ). The A/C shops say the entire system (condenser, evaporator, lines, etc. ) needs to be removed, cleaned and reinstalled. Needless to say this will be extremely expensive.
I think this is overkill. The system has not been opened to atmosphere (yet) since the incident, so if I remove the compressor, check for debris in the lines, install the new compressor then have it vacuumed & recharged this should be fine, right?
Does anyone have any experience or opinions on this?
Thanks in advance.
Thanks in advance.
