Hi, I have a leak in the a/c lines where they were rubbing together for a few years and need to replace both high & low pressure lines. There is some type of quick connect fitting at each end of the lines. Do I need a special tool to remove these? Since the system has a leak, do I need to have the system emptied? Can I safely remove the existing lines without anything blowing up because of a pressurized system? Thanks, John
