I have an opportunity to obtain an HX35W turbo really cheap. The problem is that it has been through a fire and the turbine is locked. My first question is if this turbo will be rebuildable. My second question is if this will make a good candidate for my truck(see sig) after I install the second gen intercooler and plumbing. I'm normally running empty back and forth to work, when I do pull it normally is forage wagons below 30mph or the wood wagon with 3-5 cords of wood on it. Any thoughts on this would be greatly appreciated.
Thank you.
The smiling ex-dealer technician
89 w250, 47rh trans, cleaned up exhaust, Dynomax bullet muffer, 3" lift, unknown oversized injectors
Thank you.
