ABS and brake light comes on
u-joint needed for 2003 automatic
strange map light problem
This week my abs and brake light has come on but goes off and comes on again. What can be wrong?? Pedal feels a little squishey and vibrating as if on ice. Jim
take it for a short drive. 5 miles or so and see if the front hubs are hot. If so they need to be replaced.
Can you hear a hum from under the hood when the pedal shakes?
Does it shake all the time or just while moving?
If there is some one close to you with a SMARTY they should be able to pull the codes for you.
Does it shake all the time or just while mooving?
My break and ABS lights did the same. Checked with Smarty, no codes. I cleared the codes that were not there, with Smarty, lights went out.
