Engine/Transmission (1998.5 - 2002) ABS and Brake light
Engine/Transmission (1998.5 - 2002) IN-Tank Lift Pump or Not
Engine/Transmission (1994 - 1998) low range 2wd
my ABS light and brake light are on and the speedometer jumps all around, I already replaced the sensor on top of the rear axle. Does anybody know what else could cause this?
thanks,
Cory
Check for chafed wiring where the wires go from the frame to the axle. If the wiring checks ok you may have to open the differential and check out the tone ring.
Dave
Just repaired this problem
:) Finally figured out why my brake and ABS lights were on forever. I wasn't tipped off to the real problem until the speedo started acting weird.
There is whats called a WSS or wheel speed sensor mounted in the top of the rear differential. It sends an AC signal to the ABS controller and also the speedo. This gizmo replaced the old style VSS or vehicle speed sensor. It must have been sending an erratic signal that proggressively got worse. After I replaced it, the lights went out and the speedo works fine.
Hope this helps.
Part# 56028187- AE Sensor WH 8037155
