Hi All,
I have a 1998. 5 Dodge Ram with 4WD and 4 wheel ABS. The ABS and brake warning lights have been coming on on the dashboard intermittently now for the past few weeks.
I did a search in the forums and found some other people having this problem. One suggestion was to replace the rear wheel speed sensor. Well... I tried that and it didn't solve the problem. I did see another thread that suggests a possible vacuum leak, but I'm not sure what tools I would need to help track that down.
The truck is also starting to get some noise when you turn the steering wheel pretty far... my guess is the power steering pump is starting to go. I only mention this in case it may somehow be related to the ABS and Brake light issue. The truck's brake lights do work, so it would not appear to be the brake light switch.
The brakes appear to work ok except for some warped rotors.
I went to Autozone and had them check the codes from the computer. Not sure if any of these are related, but here's what they have:
622
463
1693
Anyone have ideas on where I should look next ?
Thanks,
--Phil
622
463
1693
Thanks,
--Phil
