Here is my problem..... Two days ago my brake light and ABS light both illuminated. They will come on and go off every 10-30 seconds. The trucks ABS function is applying sometimes (not always) when brakes are applied. Now yesterday my truck doesn't want to go into overdrive. I know that the transmission is fine as I can manually apply 4th via a wired switch I have. Also the TC does not lock in 3rd or 4th unless I use a manual lockup switch.
So any ideas? I am thinking one of the ABS sensors might be the culprit, but any help is appreciated.
Thanks,
Doug
Thanks,
Doug
