Details here: TDR Privileges
hey guys, every now and then (abs) light flashes for a second, is there something i should be looking for, I do pull a camper at times. anyone now what it could be. 59,000 ml.
There was a recall on a spring under the steering while because it was breaking. Could it be this is beginning to fail? Cannot remember the exact name of the spring but I am sure others know and will chime in. I know before I had mine changed under warrantly my ABS light would come on when turning the steering while then finally it just stayed on all the time. Hope this helps.
I think that spring is called the clock spring. . and I just had to trouble shoot mine as well, there is a senser on top of the chunck in the rearend. It controls the spedometer and the ABS. Thats what the dealership told me to check first. I replaced it for about $40. 00 from the dealership. It ended up being loose plugs on mine to fix the problem. . also, on the driver side under the hood there are 2 plugs in the corner next to the fire wall right up on top. that's what my problem was, they were loose. I took them off and cleaned them out and pluged them back in and my problem was fixed... hope this helps.
I had this problem over a few years where the light would come on intermittently then finally after a few years stayed on all the time.
I read the codes, followed the service manual, and replaced the ABS controller.
No change!
Finally found the problem: It was a short to frame of one of the wires coming up from the differential sensor. The location of the short on mine was close to the front fender.
